Time Before: 0.00880 seconds
Time After: 0.01110 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01117 seconds
Time After: 0.01158 seconds
Time Before: 0.01178 seconds
Time After: 0.01190 seconds
Time Before: 0.01269 seconds
Time After: 0.01529 seconds
Time Taken: 0.00260 seconds
Time Before: 0.01195 seconds
Time After: 0.01871 seconds
Time Taken: 0.00676 seconds
Time Before: 0.02358 seconds
Time After: 0.02400 seconds
Time Before: 0.02732 seconds
Time After: 0.02871 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02291 seconds
Time After: 0.02891 seconds
Time Taken: 0.00601 seconds
Memory After: 2,261.703 KB
Time Before: 0.04699 seconds
Time After: 0.04712 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05412 seconds
Time After: 0.05545 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.06041 seconds
Time After: 0.06057 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06290 seconds
Time After: 0.06437 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103830' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.08002 seconds
Time After: 0.08032 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
