Time Before: 0.00138 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00234 seconds
Time Before: 0.00254 seconds
Time After: 0.00288 seconds
Time Before: 0.00372 seconds
Time After: 0.00620 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00296 seconds
Time After: 0.00989 seconds
Time Taken: 0.00694 seconds
Time Before: 0.01186 seconds
Time After: 0.01224 seconds
Time Before: 0.01469 seconds
Time After: 0.01587 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01125 seconds
Time After: 0.01604 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02116 seconds
Time After: 0.02129 seconds
Time Before: 0.02366 seconds
Time After: 0.02494 seconds
End call of global.php: 0.026626825332642
Time Before: 0.02790 seconds
Time After: 0.02805 seconds
Time Before: 0.03105 seconds
Time After: 0.03285 seconds
Time Taken: 0.00180 seconds
SET lastactivity = 1789125312, location = '/forums/private.php?do=newpm&explain=1&u=103855', badlocation = 1
Time Before: 0.04861 seconds
Time After: 0.04889 seconds
Page generated in 0.047388792037964 seconds with 9 queries, spending 0.0084068775177002 doing MySQL queries and 0.038981914520264 doing PHP things.
