Time Before: 0.00192 seconds
Time After: 0.00268 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00275 seconds
Time After: 0.00329 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00350 seconds
Time After: 0.00361 seconds
Time Before: 0.00431 seconds
Time After: 0.00627 seconds
Time Taken: 0.00196 seconds
Time Before: 0.00366 seconds
Time After: 0.00964 seconds
Time Taken: 0.00598 seconds
Time Before: 0.01277 seconds
Time After: 0.01327 seconds
Time Before: 0.01556 seconds
Time After: 0.01700 seconds
Time Before: 0.01195 seconds
Time After: 0.01719 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02254 seconds
Time After: 0.02272 seconds
Time Before: 0.02522 seconds
Time After: 0.02643 seconds
Time Before: 0.02924 seconds
Time After: 0.02943 seconds
Time Before: 0.03156 seconds
Time After: 0.03352 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103862' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04736 seconds
Time After: 0.04773 seconds
