Time Before: 0.02471 seconds
Time After: 0.03212 seconds
Time Taken: 0.00741 seconds
Time Before: 0.03223 seconds
Time After: 0.03265 seconds
Time Before: 0.03296 seconds
Time After: 0.03316 seconds
Time Before: 0.03396 seconds
Time After: 0.03588 seconds
Time Taken: 0.00192 seconds
Time Before: 0.03324 seconds
Time After: 0.04039 seconds
Time Taken: 0.00714 seconds
Time Before: 0.04704 seconds
Time After: 0.04745 seconds
Time Before: 0.04887 seconds
Time After: 0.05008 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04624 seconds
Time After: 0.05028 seconds
Time Taken: 0.00404 seconds
Memory After: 2,261.820 KB
Time Before: 0.11099 seconds
Time After: 0.11116 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.12990 seconds
Time After: 0.13115 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.13326501846313
Time Before: 0.14315 seconds
Time After: 0.14334 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.14604 seconds
Time After: 0.14751 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789147939, location = '/forums/private.php?do=newpm&explain=1&u=103879'
Time Before: 0.16927 seconds
Time After: 0.16953 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.16828799247742 seconds with 9 queries, spending 0.0075168609619141 doing MySQL queries and 0.1607711315155 doing PHP things.
