Time Before: 0.00143 seconds
Time After: 0.00202 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00209 seconds
Time After: 0.00249 seconds
Time Before: 0.00275 seconds
Time After: 0.00290 seconds
Time Before: 0.00357 seconds
Time After: 0.00653 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00295 seconds
Time After: 0.01102 seconds
Time Taken: 0.00807 seconds
Time Before: 0.01338 seconds
Time After: 0.01384 seconds
Time Before: 0.01644 seconds
Time After: 0.01905 seconds
Time Taken: 0.00261 seconds
Time Before: 0.01261 seconds
Time After: 0.01922 seconds
Time Taken: 0.00661 seconds
Time Before: 0.02470 seconds
Time After: 0.02502 seconds
Time Before: 0.02697 seconds
Time After: 0.02828 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03113 seconds
Time After: 0.03129 seconds
Time Before: 0.03339 seconds
Time After: 0.03518 seconds
Time Taken: 0.00178 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103883' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04999 seconds
Time After: 0.05031 seconds
