Time Before: 0.00580 seconds
Time After: 0.00742 seconds
Time Taken: 0.00162 seconds
Time Before: 0.00750 seconds
Time After: 0.00796 seconds
Time Before: 0.00824 seconds
Time After: 0.00835 seconds
Time Before: 0.00909 seconds
Time After: 0.01125 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00840 seconds
Time After: 0.01699 seconds
Time Taken: 0.00858 seconds
Time Before: 0.02065 seconds
Time After: 0.02108 seconds
Time Before: 0.02387 seconds
Time After: 0.02530 seconds
Time Before: 0.01983 seconds
Time After: 0.02555 seconds
Time Taken: 0.00571 seconds
Time Before: 0.04092 seconds
Time After: 0.04111 seconds
Time Before: 0.04668 seconds
Time After: 0.04794 seconds
Time Before: 0.05496 seconds
Time After: 0.05512 seconds
Time Before: 0.05811 seconds
Time After: 0.05973 seconds
UPDATE session SET lastactivity = 1784775752, location = '/forums/private.php?do=newpm&explain=1&u=103884' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.08207 seconds
Time After: 0.08235 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
