Time Before: 0.01910 seconds
Time After: 0.02439 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02450 seconds
Time After: 0.02499 seconds
Time Before: 0.02524 seconds
Time After: 0.02540 seconds
Time Before: 0.02632 seconds
Time After: 0.02861 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02549 seconds
Time After: 0.03323 seconds
Time Taken: 0.00773 seconds
Time Before: 0.04227 seconds
Time After: 0.04304 seconds
Time Taken: 0.00077 seconds
Time Before: 0.04557 seconds
Time After: 0.04687 seconds
Time Before: 0.04134 seconds
Time After: 0.04714 seconds
Time Taken: 0.00580 seconds
Time Before: 0.09250 seconds
Time After: 0.09267 seconds
Time Before: 0.11040 seconds
Time After: 0.11173 seconds
Time Taken: 0.00133 seconds
Time Before: 0.12428 seconds
Time After: 0.12448 seconds
Time Before: 0.12711 seconds
Time After: 0.12867 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103885' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14691 seconds
Time After: 0.14720 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
