Time Before: 0.02357 seconds
Time After: 0.03173 seconds
Time Taken: 0.00816 seconds
Time Before: 0.03180 seconds
Time After: 0.03224 seconds
Time Before: 0.03252 seconds
Time After: 0.03268 seconds
Time Before: 0.03349 seconds
Time After: 0.03613 seconds
Time Taken: 0.00263 seconds
Time Before: 0.03275 seconds
Time After: 0.04044 seconds
Time Taken: 0.00769 seconds
Time Before: 0.04809 seconds
Time After: 0.04850 seconds
Time Before: 0.05108 seconds
Time After: 0.05233 seconds
Time Before: 0.04728 seconds
Time After: 0.05266 seconds
Time Taken: 0.00538 seconds
Memory After: 2,262.484 KB
Memory Used: 132.898 KB
Time Before: 0.10290 seconds
Time After: 0.10304 seconds
Memory Before: 2,816.055 KB
Memory After: 2,816.570 KB
Time Before: 0.12995 seconds
Time After: 0.13122 seconds
Memory Before: 2,904.250 KB
Memory After: 2,904.844 KB
Time Before: 0.14095 seconds
Time After: 0.14111 seconds
Memory Before: 3,541.008 KB
Memory After: 3,541.438 KB
Time Before: 0.14382 seconds
Time After: 0.14529 seconds
Memory Before: 3,822.586 KB
Memory After: 3,824.273 KB
UPDATE session SET lastactivity = 1785380586, location = '/forums/private.php?do=newpm&explain=1&u=103889', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.16444 seconds
Time After: 0.16470 seconds
Memory Before: 4,288.492 KB
Memory After: 4,288.703 KB
