Time Before: 0.00856 seconds
Time After: 0.01032 seconds
Time Taken: 0.00176 seconds
Time Before: 0.01043 seconds
Time After: 0.01092 seconds
Time Before: 0.01112 seconds
Time After: 0.01126 seconds
Time Before: 0.01217 seconds
Time After: 0.01455 seconds
Time Taken: 0.00238 seconds
Time Before: 0.01132 seconds
Time After: 0.01843 seconds
Time Taken: 0.00711 seconds
Time Before: 0.02176 seconds
Time After: 0.02210 seconds
Time Before: 0.02438 seconds
Time After: 0.02556 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02117 seconds
Time After: 0.02580 seconds
Time Taken: 0.00464 seconds
Time Before: 0.03747 seconds
Time After: 0.03762 seconds
Time Before: 0.04503 seconds
Time After: 0.04625 seconds
End call of global.php: 0.048365831375122
Time Before: 0.05154 seconds
Time After: 0.05169 seconds
Time Before: 0.05454 seconds
Time After: 0.05597 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=103902', badlocation = 1
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.06951 seconds
Time After: 0.06978 seconds
Page generated in 0.068572998046875 seconds with 9 queries, spending 0.0077428817749023 doing MySQL queries and 0.060830116271973 doing PHP things.
