Time Before: 0.00450 seconds
Time After: 0.00536 seconds
Time Taken: 0.00086 seconds
Time Before: 0.00548 seconds
Time After: 0.00593 seconds
Time Before: 0.00625 seconds
Time After: 0.00637 seconds
Time Before: 0.00737 seconds
Time After: 0.00975 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00645 seconds
Time After: 0.01518 seconds
Time Taken: 0.00873 seconds
Time Before: 0.01771 seconds
Time After: 0.01814 seconds
Time Before: 0.02133 seconds
Time After: 0.02256 seconds
Time Before: 0.01690 seconds
Time After: 0.02281 seconds
Time Taken: 0.00591 seconds
Time Before: 0.02926 seconds
Time After: 0.02948 seconds
Time Before: 0.03196 seconds
Time After: 0.03344 seconds
Time Before: 0.03781 seconds
Time After: 0.03798 seconds
Time Before: 0.04100 seconds
Time After: 0.04275 seconds
Time Taken: 0.00176 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=103926', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.05600 seconds
Time After: 0.05630 seconds
