Time Before: 0.02987 seconds
Time After: 0.03701 seconds
Time Taken: 0.00714 seconds
Time Before: 0.03710 seconds
Time After: 0.03758 seconds
Time Before: 0.03784 seconds
Time After: 0.03832 seconds
Time Before: 0.03974 seconds
Time After: 0.04178 seconds
Time Taken: 0.00204 seconds
Time Before: 0.03840 seconds
Time After: 0.04692 seconds
Time Taken: 0.00852 seconds
Time Before: 0.05963 seconds
Time After: 0.06002 seconds
Time Before: 0.06353 seconds
Time After: 0.06475 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05879 seconds
Time After: 0.06503 seconds
Time Taken: 0.00624 seconds
Memory After: 2,261.820 KB
Time Before: 0.10533 seconds
Time After: 0.10548 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.12289 seconds
Time After: 0.12413 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.13488 seconds
Time After: 0.13504 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13771 seconds
Time After: 0.13917 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788933313, location = '/forums/private.php?do=newpm&explain=1&u=103974', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15693 seconds
Time After: 0.15721 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
