Time Before: 0.01155 seconds
Time After: 0.01618 seconds
Time Taken: 0.00463 seconds
Time Before: 0.01628 seconds
Time After: 0.01666 seconds
Time Before: 0.01689 seconds
Time After: 0.01703 seconds
Time Before: 0.01788 seconds
Time After: 0.02037 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01710 seconds
Time After: 0.02431 seconds
Time Taken: 0.00720 seconds
Time Before: 0.02861 seconds
Time After: 0.02905 seconds
Time Before: 0.03225 seconds
Time After: 0.03451 seconds
Time Taken: 0.00226 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02790 seconds
Time After: 0.03472 seconds
Time Taken: 0.00682 seconds
Memory After: 2,261.703 KB
Time Before: 0.05344 seconds
Time After: 0.05358 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06446 seconds
Time After: 0.06569 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.068008899688721
Time Before: 0.07236 seconds
Time After: 0.07250 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07544 seconds
Time After: 0.07697 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=103979', badlocation = 1
Time Before: 0.09670 seconds
Time After: 0.09697 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.095448970794678 seconds with 9 queries, spending 0.0090155601501465 doing MySQL queries and 0.086433410644531 doing PHP things.
