Time Before: 0.00670 seconds
Time After: 0.01082 seconds
Time Taken: 0.00412 seconds
Time Before: 0.01091 seconds
Time After: 0.01139 seconds
Time Before: 0.01164 seconds
Time After: 0.01186 seconds
Time Before: 0.01267 seconds
Time After: 0.01501 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01192 seconds
Time After: 0.02059 seconds
Time Taken: 0.00867 seconds
Time Before: 0.02601 seconds
Time After: 0.02626 seconds
Time Before: 0.02875 seconds
Time After: 0.02994 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02520 seconds
Time After: 0.03020 seconds
Time Taken: 0.00500 seconds
Time Before: 0.05085 seconds
Time After: 0.05181 seconds
Time Taken: 0.00095 seconds
Time Before: 0.14308 seconds
Time After: 0.14432 seconds
End call of global.php: 0.14673113822937
Time Before: 0.15155 seconds
Time After: 0.15175 seconds
Time Before: 0.15483 seconds
Time After: 0.15676 seconds
Time Taken: 0.00193 seconds
SET lastactivity = 1776582915, location = '/forums/private.php?do=newpm&explain=1&u=10398'
Time Before: 0.17476 seconds
Time After: 0.17503 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.17367315292358 seconds with 9 queries, spending 0.0090513229370117 doing MySQL queries and 0.16462182998657 doing PHP things.
