Time Before: 0.02704 seconds
Time After: 0.03415 seconds
Time Taken: 0.00711 seconds
Time Before: 0.03426 seconds
Time After: 0.03482 seconds
Time Taken: 0.00057 seconds
Time Before: 0.03511 seconds
Time After: 0.03526 seconds
Time Before: 0.03600 seconds
Time After: 0.03821 seconds
Time Taken: 0.00222 seconds
Time Before: 0.03534 seconds
Time After: 0.04275 seconds
Time Taken: 0.00742 seconds
Time Before: 0.05032 seconds
Time After: 0.05069 seconds
Time Before: 0.05315 seconds
Time After: 0.05433 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04970 seconds
Time After: 0.05456 seconds
Time Taken: 0.00486 seconds
Time Before: 0.08527 seconds
Time After: 0.08542 seconds
Time Before: 0.30143 seconds
Time After: 0.30280 seconds
Time Taken: 0.00137 seconds
Time Before: 0.31233 seconds
Time After: 0.31251 seconds
Time Before: 0.31545 seconds
Time After: 0.31694 seconds
UPDATE session SET lastactivity = 1783092171, location = '/forums/private.php?do=newpm&explain=1&u=103999', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.33883 seconds
Time After: 0.33910 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
