Time Before: 0.03575 seconds
Time After: 0.05044 seconds
Time Taken: 0.01469 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.05054 seconds
Time After: 0.05117 seconds
Time Taken: 0.00063 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.05145 seconds
Time After: 0.05160 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.05244 seconds
Time After: 0.05522 seconds
Time Taken: 0.00278 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.05170 seconds
Time After: 0.06097 seconds
Time Taken: 0.00928 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.07736 seconds
Time After: 0.07776 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.08042 seconds
Time After: 0.08165 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.07671 seconds
Time After: 0.08188 seconds
Time Taken: 0.00518 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.13845 seconds
Time After: 0.13859 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.22684 seconds
Time After: 0.22816 seconds
Time Taken: 0.00132 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.23103594779968
Time Before: 0.26440 seconds
Time After: 0.26460 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.27323 seconds
Time After: 0.27574 seconds
Time Taken: 0.00251 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=104122', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.30997 seconds
Time After: 0.31025 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
Page generated in 0.30884909629822 seconds with 9 queries, spending 0.0096397399902344 doing MySQL queries and 0.29920935630798 doing PHP things.
