Time Before: 0.00207 seconds
Time After: 0.00284 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00292 seconds
Time After: 0.00334 seconds
Time Before: 0.00353 seconds
Time After: 0.00362 seconds
Time Taken: 0.00009 seconds
Time Before: 0.00416 seconds
Time After: 0.00631 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00367 seconds
Time After: 0.00968 seconds
Time Taken: 0.00601 seconds
Time Before: 0.01149 seconds
Time After: 0.01187 seconds
Time Before: 0.01371 seconds
Time After: 0.01487 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01087 seconds
Time After: 0.01506 seconds
Time Taken: 0.00419 seconds
Memory After: 2,261.820 KB
Time Before: 0.02007 seconds
Time After: 0.02024 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02234 seconds
Time After: 0.02383 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.025449991226196
Time Before: 0.02643 seconds
Time After: 0.02658 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.02841 seconds
Time After: 0.02989 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788955161, location = '/forums/private.php?do=newpm&explain=1&u=104128'
Time Before: 0.04537 seconds
Time After: 0.04564 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.043948888778687 seconds with 9 queries, spending 0.0077688694000244 doing MySQL queries and 0.036180019378662 doing PHP things.
