Time Before: 0.00441 seconds
Time After: 0.00700 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00710 seconds
Time After: 0.00752 seconds
Time Before: 0.00774 seconds
Time After: 0.00787 seconds
Time Before: 0.00872 seconds
Time After: 0.01157 seconds
Time Taken: 0.00285 seconds
Time Before: 0.00795 seconds
Time After: 0.01690 seconds
Time Taken: 0.00896 seconds
Time Before: 0.01987 seconds
Time After: 0.02011 seconds
Time Before: 0.02284 seconds
Time After: 0.02411 seconds
Time Before: 0.01908 seconds
Time After: 0.02438 seconds
Time Taken: 0.00530 seconds
Time Before: 0.03169 seconds
Time After: 0.03186 seconds
Time Before: 0.03664 seconds
Time After: 0.03854 seconds
Time Taken: 0.00189 seconds
Time Before: 0.04228 seconds
Time After: 0.04243 seconds
Time Before: 0.04567 seconds
Time After: 0.04730 seconds
Time Taken: 0.00162 seconds
UPDATE session SET lastactivity = 1783182018, location = '/forums/private.php?do=newpm&explain=1&u=104132', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.06837 seconds
Time After: 0.06865 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
