Time Before: 0.00230 seconds
Time After: 0.00297 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00309 seconds
Time After: 0.00370 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00397 seconds
Time After: 0.00411 seconds
Time Before: 0.00479 seconds
Time After: 0.00730 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00416 seconds
Time After: 0.01115 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01288 seconds
Time After: 0.01326 seconds
Time Before: 0.01570 seconds
Time After: 0.01724 seconds
Time Taken: 0.00154 seconds
Time Before: 0.01233 seconds
Time After: 0.01748 seconds
Time Taken: 0.00515 seconds
Time Before: 0.02474 seconds
Time After: 0.02488 seconds
Time Before: 0.02678 seconds
Time After: 0.02807 seconds
Time Before: 0.03111 seconds
Time After: 0.03127 seconds
Time Before: 0.03338 seconds
Time After: 0.03517 seconds
Time Taken: 0.00180 seconds
UPDATE session SET lastactivity = 1788961252, location = '/forums/private.php?do=newpm&explain=1&u=104158', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04779 seconds
Time After: 0.04815 seconds
