Time Before: 0.01660 seconds
Time After: 0.02492 seconds
Time Taken: 0.00832 seconds
Time Before: 0.02504 seconds
Time After: 0.02567 seconds
Time Taken: 0.00064 seconds
Time Before: 0.02593 seconds
Time After: 0.02606 seconds
Time Before: 0.02693 seconds
Time After: 0.02888 seconds
Time Taken: 0.00195 seconds
Time Before: 0.02613 seconds
Time After: 0.03314 seconds
Time Taken: 0.00701 seconds
Time Before: 0.04343 seconds
Time After: 0.04377 seconds
Time Before: 0.04653 seconds
Time After: 0.04779 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04270 seconds
Time After: 0.04800 seconds
Time Taken: 0.00530 seconds
Memory After: 2,261.703 KB
Time Before: 0.07026 seconds
Time After: 0.07043 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08847 seconds
Time After: 0.08972 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.09875 seconds
Time After: 0.09893 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10161 seconds
Time After: 0.10308 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104184' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.12304 seconds
Time After: 0.12329 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
