Time Before: 0.01865 seconds
Time After: 0.02662 seconds
Time Taken: 0.00798 seconds
Time Before: 0.02670 seconds
Time After: 0.02711 seconds
Time Before: 0.02735 seconds
Time After: 0.02753 seconds
Time Before: 0.02839 seconds
Time After: 0.03054 seconds
Time Taken: 0.00216 seconds
Time Before: 0.02761 seconds
Time After: 0.03524 seconds
Time Taken: 0.00763 seconds
Time Before: 0.04644 seconds
Time After: 0.04684 seconds
Time Before: 0.04975 seconds
Time After: 0.05092 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04578 seconds
Time After: 0.05116 seconds
Time Taken: 0.00538 seconds
Time Before: 0.09102 seconds
Time After: 0.09120 seconds
Time Before: 0.11318 seconds
Time After: 0.11444 seconds
Time Before: 0.12076 seconds
Time After: 0.12091 seconds
Time Before: 0.12364 seconds
Time After: 0.12507 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104189' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.14185 seconds
Time After: 0.14217 seconds
