Time Before: 0.00473 seconds
Time After: 0.00589 seconds
Time Taken: 0.00116 seconds
Time Before: 0.00596 seconds
Time After: 0.00638 seconds
Time Before: 0.00669 seconds
Time After: 0.00685 seconds
Time Before: 0.00778 seconds
Time After: 0.01000 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00692 seconds
Time After: 0.01528 seconds
Time Taken: 0.00835 seconds
Time Before: 0.01831 seconds
Time After: 0.01874 seconds
Time Before: 0.02225 seconds
Time After: 0.02350 seconds
Time Before: 0.01752 seconds
Time After: 0.02380 seconds
Time Taken: 0.00628 seconds
Time Before: 0.03683 seconds
Time After: 0.03698 seconds
Time Before: 0.04185 seconds
Time After: 0.04325 seconds
Time Taken: 0.00140 seconds
Time Before: 0.04716 seconds
Time After: 0.04755 seconds
Time Before: 0.04964 seconds
Time After: 0.05110 seconds
UPDATE session SET lastactivity = 1785290390, location = '/forums/private.php?do=newpm&explain=1&u=104190', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.06910 seconds
Time After: 0.06941 seconds
