Time Before: 0.01349 seconds
Time After: 0.01872 seconds
Time Taken: 0.00524 seconds
Time Before: 0.01887 seconds
Time After: 0.01938 seconds
Time Before: 0.01974 seconds
Time After: 0.01987 seconds
Time Before: 0.02071 seconds
Time After: 0.02303 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01997 seconds
Time After: 0.02724 seconds
Time Taken: 0.00727 seconds
Time Before: 0.03251 seconds
Time After: 0.03289 seconds
Time Before: 0.03559 seconds
Time After: 0.03679 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03180 seconds
Time After: 0.03701 seconds
Time Taken: 0.00521 seconds
Memory After: 2,261.703 KB
Time Before: 0.05719 seconds
Time After: 0.05733 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07463 seconds
Time After: 0.07589 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.08747 seconds
Time After: 0.08814 seconds
Time Taken: 0.00067 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09060 seconds
Time After: 0.09213 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104220', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.11065 seconds
Time After: 0.11090 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
