Time Before: 0.01624 seconds
Time After: 0.02107 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02116 seconds
Time After: 0.02162 seconds
Time Before: 0.02189 seconds
Time After: 0.02200 seconds
Time Before: 0.02286 seconds
Time After: 0.02529 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02206 seconds
Time After: 0.03093 seconds
Time Taken: 0.00887 seconds
Time Before: 0.03866 seconds
Time After: 0.03897 seconds
Time Before: 0.04093 seconds
Time After: 0.04361 seconds
Time Taken: 0.00268 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03806 seconds
Time After: 0.04384 seconds
Time Taken: 0.00579 seconds
Memory After: 2,261.703 KB
Time Before: 0.06260 seconds
Time After: 0.06271 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08210 seconds
Time After: 0.08333 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.09826 seconds
Time After: 0.09841 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10201 seconds
Time After: 0.10474 seconds
Time Taken: 0.00273 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104256' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.12716 seconds
Time After: 0.12742 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
