Time Before: 0.00819 seconds
Time After: 0.01056 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01063 seconds
Time After: 0.01105 seconds
Time Before: 0.01127 seconds
Time After: 0.01139 seconds
Time Before: 0.01218 seconds
Time After: 0.01493 seconds
Time Taken: 0.00275 seconds
Time Before: 0.01144 seconds
Time After: 0.01924 seconds
Time Taken: 0.00780 seconds
Time Before: 0.02387 seconds
Time After: 0.02414 seconds
Time Before: 0.02646 seconds
Time After: 0.02770 seconds
Time Before: 0.02320 seconds
Time After: 0.02790 seconds
Time Taken: 0.00470 seconds
Time Before: 0.04371 seconds
Time After: 0.04390 seconds
Time Before: 0.04956 seconds
Time After: 0.05081 seconds
Time Before: 0.05640 seconds
Time After: 0.05656 seconds
Time Before: 0.05878 seconds
Time After: 0.06023 seconds
UPDATE session SET lastactivity = 1783005997, location = '/forums/private.php?do=newpm&explain=1&u=104274', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.07522 seconds
Time After: 0.07550 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
