Time Before: 0.01673 seconds
Time After: 0.02114 seconds
Time Taken: 0.00441 seconds
Time Before: 0.02125 seconds
Time After: 0.02170 seconds
Time Before: 0.02197 seconds
Time After: 0.02213 seconds
Time Before: 0.02297 seconds
Time After: 0.02524 seconds
Time Taken: 0.00227 seconds
Time Before: 0.02221 seconds
Time After: 0.02938 seconds
Time Taken: 0.00717 seconds
Time Before: 0.03666 seconds
Time After: 0.03711 seconds
Time Before: 0.03992 seconds
Time After: 0.04112 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03595 seconds
Time After: 0.04134 seconds
Time Taken: 0.00539 seconds
Memory After: 2,261.703 KB
Time Before: 0.07201 seconds
Time After: 0.07218 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08605 seconds
Time After: 0.08735 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.090204954147339
Time Before: 0.09644 seconds
Time After: 0.09662 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10010 seconds
Time After: 0.10152 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=104286', badlocation = 1
Time Before: 0.11891 seconds
Time After: 0.11920 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.11795997619629 seconds with 9 queries, spending 0.0078966617584229 doing MySQL queries and 0.11006331443787 doing PHP things.
