Time Before: 0.02658 seconds
Time After: 0.03264 seconds
Time Taken: 0.00606 seconds
Time Before: 0.03275 seconds
Time After: 0.03328 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03352 seconds
Time After: 0.03367 seconds
Time Before: 0.03442 seconds
Time After: 0.03738 seconds
Time Taken: 0.00297 seconds
Time Before: 0.03373 seconds
Time After: 0.04172 seconds
Time Taken: 0.00799 seconds
Time Before: 0.05084 seconds
Time After: 0.05105 seconds
Time Before: 0.05373 seconds
Time After: 0.05504 seconds
Time Taken: 0.00131 seconds
Time Before: 0.05018 seconds
Time After: 0.05526 seconds
Time Taken: 0.00508 seconds
Time Before: 0.09754 seconds
Time After: 0.09772 seconds
Time Before: 0.60376 seconds
Time After: 0.60567 seconds
Time Taken: 0.00191 seconds
Time Before: 0.62245 seconds
Time After: 0.62262 seconds
Time Before: 0.62508 seconds
Time After: 0.62666 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104287', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.64921 seconds
Time After: 0.64946 seconds
