Time Before: 0.00131 seconds
Time After: 0.00178 seconds
Time Before: 0.00185 seconds
Time After: 0.00228 seconds
Time Before: 0.00249 seconds
Time After: 0.00263 seconds
Time Before: 0.00335 seconds
Time After: 0.00593 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00268 seconds
Time After: 0.01068 seconds
Time Taken: 0.00799 seconds
Time Before: 0.01246 seconds
Time After: 0.01285 seconds
Time Before: 0.01596 seconds
Time After: 0.01719 seconds
Time Before: 0.01184 seconds
Time After: 0.01743 seconds
Time Taken: 0.00558 seconds
Time Before: 0.02320 seconds
Time After: 0.02333 seconds
Time Before: 0.02529 seconds
Time After: 0.02654 seconds
Time Before: 0.02952 seconds
Time After: 0.02973 seconds
Time Before: 0.03178 seconds
Time After: 0.03329 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1789067756, location = '/forums/private.php?do=newpm&explain=1&u=104298' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04678 seconds
Time After: 0.04723 seconds
