Time Before: 0.00142 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00252 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00276 seconds
Time After: 0.00287 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00364 seconds
Time After: 0.00690 seconds
Time Taken: 0.00325 seconds
Time Before: 0.00291 seconds
Time After: 0.01027 seconds
Time Taken: 0.00735 seconds
Time Before: 0.01199 seconds
Time After: 0.01232 seconds
Time Before: 0.01494 seconds
Time After: 0.01623 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01144 seconds
Time After: 0.01640 seconds
Time Taken: 0.00497 seconds
Memory After: 2,261.703 KB
Time Before: 0.02134 seconds
Time After: 0.02148 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02335 seconds
Time After: 0.02457 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02748 seconds
Time After: 0.02766 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02958 seconds
Time After: 0.03102 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104316', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04329 seconds
Time After: 0.04363 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
