Time Before: 0.00235 seconds
Time After: 0.00298 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00308 seconds
Time After: 0.00381 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00408 seconds
Time After: 0.00423 seconds
Time Before: 0.00488 seconds
Time After: 0.00742 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00428 seconds
Time After: 0.01083 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01305 seconds
Time After: 0.01344 seconds
Time Before: 0.01615 seconds
Time After: 0.01740 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01249 seconds
Time After: 0.01757 seconds
Time Taken: 0.00508 seconds
Memory After: 2,261.820 KB
Time Before: 0.02281 seconds
Time After: 0.02297 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02473 seconds
Time After: 0.02597 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.02886 seconds
Time After: 0.02902 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03098 seconds
Time After: 0.03243 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789127001, location = '/forums/private.php?do=newpm&explain=1&u=104335' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05085 seconds
Time After: 0.05121 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
