Time Before: 0.02962 seconds
Time After: 0.03596 seconds
Time Taken: 0.00633 seconds
Time Before: 0.03606 seconds
Time After: 0.03646 seconds
Time Before: 0.03674 seconds
Time After: 0.03690 seconds
Time Before: 0.03774 seconds
Time After: 0.03966 seconds
Time Taken: 0.00192 seconds
Time Before: 0.03696 seconds
Time After: 0.04423 seconds
Time Taken: 0.00727 seconds
Time Before: 0.05412 seconds
Time After: 0.05453 seconds
Time Before: 0.05711 seconds
Time After: 0.05837 seconds
Time Before: 0.05335 seconds
Time After: 0.05861 seconds
Time Taken: 0.00526 seconds
Time Before: 0.11322 seconds
Time After: 0.11337 seconds
Time Before: 0.13493 seconds
Time After: 0.13619 seconds
Time Before: 0.14829 seconds
Time After: 0.14912 seconds
Time Taken: 0.00083 seconds
Time Before: 0.15194 seconds
Time After: 0.15340 seconds
UPDATE session SET lastactivity = 1789127023, location = '/forums/private.php?do=newpm&explain=1&u=104336' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.17361 seconds
Time After: 0.17386 seconds
