Time Before: 0.00150 seconds
Time After: 0.00203 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00210 seconds
Time After: 0.00251 seconds
Time Before: 0.00278 seconds
Time After: 0.00291 seconds
Time Before: 0.00389 seconds
Time After: 0.00662 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00298 seconds
Time After: 0.01144 seconds
Time Taken: 0.00847 seconds
Time Before: 0.01324 seconds
Time After: 0.01362 seconds
Time Before: 0.01677 seconds
Time After: 0.01831 seconds
Time Taken: 0.00154 seconds
Time Before: 0.01264 seconds
Time After: 0.01857 seconds
Time Taken: 0.00593 seconds
Time Before: 0.02402 seconds
Time After: 0.02415 seconds
Time Before: 0.02604 seconds
Time After: 0.02734 seconds
Time Before: 0.03070 seconds
Time After: 0.03087 seconds
Time Before: 0.03396 seconds
Time After: 0.03541 seconds
UPDATE session SET lastactivity = 1776794729, location = '/forums/private.php?do=newpm&explain=1&u=104346', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.04912 seconds
Time After: 0.04948 seconds
