Time Before: 0.00145 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00245 seconds
Time Before: 0.00278 seconds
Time After: 0.00292 seconds
Time Before: 0.00368 seconds
Time After: 0.00643 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00298 seconds
Time After: 0.01014 seconds
Time Taken: 0.00716 seconds
Time Before: 0.01216 seconds
Time After: 0.01257 seconds
Time Before: 0.01570 seconds
Time After: 0.01693 seconds
Time Before: 0.01153 seconds
Time After: 0.01710 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02395 seconds
Time After: 0.02408 seconds
Time Before: 0.02600 seconds
Time After: 0.02739 seconds
Time Taken: 0.00138 seconds
End call of global.php: 0.029361009597778
Time Before: 0.03066 seconds
Time After: 0.03080 seconds
Time Before: 0.03295 seconds
Time After: 0.03440 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104377'
Time Before: 0.04737 seconds
Time After: 0.04777 seconds
Page generated in 0.046390056610107 seconds with 9 queries, spending 0.0084681510925293 doing MySQL queries and 0.037921905517578 doing PHP things.
