Time Before: 0.00139 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00241 seconds
Time Before: 0.00266 seconds
Time After: 0.00282 seconds
Time Before: 0.00377 seconds
Time After: 0.00606 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00292 seconds
Time After: 0.01183 seconds
Time Taken: 0.00890 seconds
Time Before: 0.01393 seconds
Time After: 0.01431 seconds
Time Before: 0.01716 seconds
Time After: 0.01841 seconds
Time Before: 0.01316 seconds
Time After: 0.01866 seconds
Time Taken: 0.00550 seconds
Time Before: 0.02433 seconds
Time After: 0.02449 seconds
Time Before: 0.02723 seconds
Time After: 0.02850 seconds
End call of global.php: 0.030674934387207
Time Before: 0.03230 seconds
Time After: 0.03246 seconds
Time Before: 0.03551 seconds
Time After: 0.03694 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104378'
Time Before: 0.04965 seconds
Time After: 0.04998 seconds
Page generated in 0.048773050308228 seconds with 9 queries, spending 0.007906436920166 doing MySQL queries and 0.040866613388062 doing PHP things.
