Time Before: 0.02606 seconds
Time After: 0.03546 seconds
Time Taken: 0.00940 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03556 seconds
Time After: 0.03601 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03622 seconds
Time After: 0.03640 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03724 seconds
Time After: 0.03968 seconds
Time Taken: 0.00244 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03648 seconds
Time After: 0.04362 seconds
Time Taken: 0.00715 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.05542 seconds
Time After: 0.05581 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.05711 seconds
Time After: 0.05832 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.05468 seconds
Time After: 0.05857 seconds
Time Taken: 0.00389 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.10519 seconds
Time After: 0.10536 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.12071 seconds
Time After: 0.12198 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
Time Before: 0.13519 seconds
Time After: 0.13536 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.13829 seconds
Time After: 0.13984 seconds
Time Taken: 0.00155 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
UPDATE session SET lastactivity = 1783038151, location = '/forums/private.php?do=newpm&explain=1&u=104396' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.15770 seconds
Time After: 0.15796 seconds
Memory Before: 4,295.914 KB
Memory After: 4,296.141 KB
