Time Before: 0.01851 seconds
Time After: 0.02267 seconds
Time Taken: 0.00416 seconds
Time Before: 0.02275 seconds
Time After: 0.02323 seconds
Time Before: 0.02352 seconds
Time After: 0.02366 seconds
Time Before: 0.02458 seconds
Time After: 0.02681 seconds
Time Taken: 0.00223 seconds
Time Before: 0.02374 seconds
Time After: 0.03137 seconds
Time Taken: 0.00762 seconds
Time Before: 0.03812 seconds
Time After: 0.03866 seconds
Time Taken: 0.00054 seconds
Time Before: 0.04116 seconds
Time After: 0.04237 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03724 seconds
Time After: 0.04258 seconds
Time Taken: 0.00534 seconds
Memory After: 2,261.820 KB
Time Before: 0.07881 seconds
Time After: 0.07896 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.09563 seconds
Time After: 0.09691 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.10489 seconds
Time After: 0.10532 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.10787 seconds
Time After: 0.10931 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788872166, location = '/forums/private.php?do=newpm&explain=1&u=104404' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.12778 seconds
Time After: 0.12811 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
