Time Before: 0.03020 seconds
Time After: 0.03687 seconds
Time Taken: 0.00667 seconds
Time Before: 0.03698 seconds
Time After: 0.03746 seconds
Time Before: 0.03775 seconds
Time After: 0.03791 seconds
Time Before: 0.03881 seconds
Time After: 0.04072 seconds
Time Taken: 0.00191 seconds
Time Before: 0.03801 seconds
Time After: 0.04488 seconds
Time Taken: 0.00687 seconds
Time Before: 0.05482 seconds
Time After: 0.05524 seconds
Time Before: 0.05786 seconds
Time After: 0.05907 seconds
Time Before: 0.05413 seconds
Time After: 0.05930 seconds
Time Taken: 0.00517 seconds
Time Before: 0.10455 seconds
Time After: 0.10471 seconds
Time Before: 0.12706 seconds
Time After: 0.12836 seconds
End call of global.php: 0.13059711456299
Time Before: 0.13806 seconds
Time After: 0.13824 seconds
Time Before: 0.14119 seconds
Time After: 0.14266 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104411'
Time Before: 0.16246 seconds
Time After: 0.16273 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
Page generated in 0.16143012046814 seconds with 9 queries, spending 0.0075392723083496 doing MySQL queries and 0.15389084815979 doing PHP things.
