Time Before: 0.00560 seconds
Time After: 0.00872 seconds
Time Taken: 0.00312 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.00880 seconds
Time After: 0.00926 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.00991 seconds
Time After: 0.01036 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.01113 seconds
Time After: 0.01388 seconds
Time Taken: 0.00275 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.01043 seconds
Time After: 0.01761 seconds
Time Taken: 0.00718 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.02229 seconds
Time After: 0.02275 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.02538 seconds
Time After: 0.02664 seconds
Memory Before: 2,148.398 KB
Memory After: 2,148.258 KB
Time Before: 0.02160 seconds
Time After: 0.02683 seconds
Time Taken: 0.00523 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.281 KB
Time Before: 0.03833 seconds
Time After: 0.03846 seconds
Memory Before: 2,814.875 KB
Memory After: 2,815.391 KB
Time Before: 0.04774 seconds
Time After: 0.04900 seconds
Memory Before: 2,903.211 KB
Memory After: 2,903.805 KB
End call of global.php: 0.050656080245972
Time Before: 0.05475 seconds
Time After: 0.05488 seconds
Memory Before: 3,539.984 KB
Memory After: 3,540.414 KB
Time Before: 0.05690 seconds
Time After: 0.05835 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
SET lastactivity = 1789079263, location = '/forums/private.php?do=newpm&explain=1&u=104426'
Time Before: 0.08216 seconds
Time After: 0.08253 seconds
Memory Before: 4,295.383 KB
Memory After: 4,295.609 KB
Page generated in 0.080703973770142 seconds with 9 queries, spending 0.008720874786377 doing MySQL queries and 0.071983098983765 doing PHP things.
