Time Before: 0.00785 seconds
Time After: 0.00946 seconds
Time Taken: 0.00161 seconds
Time Before: 0.00957 seconds
Time After: 0.01005 seconds
Time Before: 0.01031 seconds
Time After: 0.01045 seconds
Time Before: 0.01143 seconds
Time After: 0.01409 seconds
Time Taken: 0.00266 seconds
Time Before: 0.01054 seconds
Time After: 0.01969 seconds
Time Taken: 0.00915 seconds
Time Before: 0.02322 seconds
Time After: 0.02369 seconds
Time Before: 0.02626 seconds
Time After: 0.02788 seconds
Time Taken: 0.00162 seconds
Time Before: 0.02242 seconds
Time After: 0.02818 seconds
Time Taken: 0.00576 seconds
Time Before: 0.04645 seconds
Time After: 0.04669 seconds
Time Before: 0.05365 seconds
Time After: 0.05495 seconds
Time Before: 0.05981 seconds
Time After: 0.05997 seconds
Time Before: 0.06197 seconds
Time After: 0.06342 seconds
UPDATE session SET lastactivity = 1785408348, location = '/forums/private.php?do=newpm&explain=1&u=104463', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.08341 seconds
Time After: 0.08369 seconds
