Time Before: 0.00144 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00248 seconds
Time Before: 0.00271 seconds
Time After: 0.00285 seconds
Time Before: 0.00357 seconds
Time After: 0.00656 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00291 seconds
Time After: 0.00996 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01169 seconds
Time After: 0.01207 seconds
Time Before: 0.01444 seconds
Time After: 0.01563 seconds
Time Before: 0.01114 seconds
Time After: 0.01581 seconds
Time Taken: 0.00466 seconds
Time Before: 0.02072 seconds
Time After: 0.02087 seconds
Time Before: 0.02285 seconds
Time After: 0.02416 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.025795936584473
Time Before: 0.02700 seconds
Time After: 0.02720 seconds
Time Before: 0.02937 seconds
Time After: 0.03131 seconds
Time Taken: 0.00194 seconds
SET lastactivity = 1776672437, location = '/forums/private.php?do=newpm&explain=1&u=104471'
Time Before: 0.04393 seconds
Time After: 0.04432 seconds
Page generated in 0.043029069900513 seconds with 9 queries, spending 0.0091843605041504 doing MySQL queries and 0.033844709396362 doing PHP things.
