Time Before: 0.00140 seconds
Time After: 0.00197 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00204 seconds
Time After: 0.00257 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00291 seconds
Time After: 0.00305 seconds
Time Before: 0.00386 seconds
Time After: 0.00680 seconds
Time Taken: 0.00294 seconds
Time Before: 0.00312 seconds
Time After: 0.01135 seconds
Time Taken: 0.00823 seconds
Time Before: 0.01313 seconds
Time After: 0.01356 seconds
Time Before: 0.01620 seconds
Time After: 0.01758 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01247 seconds
Time After: 0.01783 seconds
Time Taken: 0.00537 seconds
Time Before: 0.02286 seconds
Time After: 0.02304 seconds
Time Before: 0.02550 seconds
Time After: 0.02681 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.029470920562744
Time Before: 0.03092 seconds
Time After: 0.03112 seconds
Time Before: 0.03377 seconds
Time After: 0.03524 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104481', badlocation = 1
Time Before: 0.04905 seconds
Time After: 0.04940 seconds
Page generated in 0.048151016235352 seconds with 9 queries, spending 0.0089459419250488 doing MySQL queries and 0.039205074310303 doing PHP things.
