Time Before: 0.00841 seconds
Time After: 0.01175 seconds
Time Taken: 0.00334 seconds
Time Before: 0.01183 seconds
Time After: 0.01241 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01271 seconds
Time After: 0.01291 seconds
Time Before: 0.01379 seconds
Time After: 0.01613 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01299 seconds
Time After: 0.02049 seconds
Time Taken: 0.00750 seconds
Time Before: 0.02456 seconds
Time After: 0.02496 seconds
Time Before: 0.02750 seconds
Time After: 0.02875 seconds
Time Before: 0.02384 seconds
Time After: 0.02900 seconds
Time Taken: 0.00517 seconds
Time Before: 0.04889 seconds
Time After: 0.04914 seconds
Time Before: 0.05665 seconds
Time After: 0.05801 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.060286998748779
Time Before: 0.06256 seconds
Time After: 0.06273 seconds
Time Before: 0.06552 seconds
Time After: 0.06707 seconds
Time Taken: 0.00155 seconds
SET lastactivity = 1785414660, location = '/forums/private.php?do=newpm&explain=1&u=104484'
Time Before: 0.08587 seconds
Time After: 0.08613 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.084738969802856 seconds with 9 queries, spending 0.0083367824554443 doing MySQL queries and 0.076402187347412 doing PHP things.
