Time Before: 0.00700 seconds
Time After: 0.00992 seconds
Time Taken: 0.00292 seconds
Time Before: 0.01000 seconds
Time After: 0.01043 seconds
Time Before: 0.01072 seconds
Time After: 0.01084 seconds
Time Before: 0.01161 seconds
Time After: 0.01401 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01091 seconds
Time After: 0.01841 seconds
Time Taken: 0.00749 seconds
Time Before: 0.02168 seconds
Time After: 0.02210 seconds
Time Before: 0.02353 seconds
Time After: 0.02472 seconds
Time Before: 0.02103 seconds
Time After: 0.02494 seconds
Time Taken: 0.00391 seconds
Time Before: 0.03858 seconds
Time After: 0.03872 seconds
Time Before: 0.04655 seconds
Time After: 0.04783 seconds
End call of global.php: 0.050256967544556
Time Before: 0.05385 seconds
Time After: 0.05401 seconds
Time Before: 0.05610 seconds
Time After: 0.05756 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104509'
Time Before: 0.07079 seconds
Time After: 0.07109 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.069849967956543 seconds with 9 queries, spending 0.0079236030578613 doing MySQL queries and 0.061926364898682 doing PHP things.
