Time Before: 0.00151 seconds
Time After: 0.00206 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00213 seconds
Time After: 0.00273 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00303 seconds
Time After: 0.00315 seconds
Time Before: 0.00392 seconds
Time After: 0.00639 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00320 seconds
Time After: 0.00983 seconds
Time Taken: 0.00663 seconds
Time Before: 0.01176 seconds
Time After: 0.01221 seconds
Time Before: 0.01540 seconds
Time After: 0.01659 seconds
Time Before: 0.01109 seconds
Time After: 0.01683 seconds
Time Taken: 0.00574 seconds
Time Before: 0.02282 seconds
Time After: 0.02296 seconds
Time Before: 0.02586 seconds
Time After: 0.02711 seconds
End call of global.php: 0.029489994049072
Time Before: 0.03127 seconds
Time After: 0.03142 seconds
Time Before: 0.03393 seconds
Time After: 0.03538 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104515', badlocation = 1
Time Before: 0.05100 seconds
Time After: 0.05148 seconds
Page generated in 0.049794912338257 seconds with 9 queries, spending 0.0083000659942627 doing MySQL queries and 0.041494846343994 doing PHP things.
