Time Before: 0.00184 seconds
Time After: 0.00243 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00252 seconds
Time After: 0.00305 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00325 seconds
Time After: 0.00335 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00407 seconds
Time After: 0.00625 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00340 seconds
Time After: 0.00965 seconds
Time Taken: 0.00625 seconds
Time Before: 0.01154 seconds
Time After: 0.01171 seconds
Time Before: 0.01474 seconds
Time After: 0.01598 seconds
Time Before: 0.01087 seconds
Time After: 0.01622 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02262 seconds
Time After: 0.02280 seconds
Time Before: 0.02472 seconds
Time After: 0.02636 seconds
Time Taken: 0.00163 seconds
Time Before: 0.02922 seconds
Time After: 0.02939 seconds
Time Before: 0.03130 seconds
Time After: 0.03274 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104516', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04511 seconds
Time After: 0.04545 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
