Time Before: 0.00134 seconds
Time After: 0.00191 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00198 seconds
Time After: 0.00251 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00281 seconds
Time After: 0.00295 seconds
Time Before: 0.00376 seconds
Time After: 0.00718 seconds
Time Taken: 0.00342 seconds
Time Before: 0.00301 seconds
Time After: 0.01058 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01303 seconds
Time After: 0.01341 seconds
Time Before: 0.01478 seconds
Time After: 0.01607 seconds
Time Before: 0.01227 seconds
Time After: 0.01624 seconds
Time Taken: 0.00398 seconds
Time Before: 0.02137 seconds
Time After: 0.02154 seconds
Time Before: 0.02382 seconds
Time After: 0.02510 seconds
Time Before: 0.02787 seconds
Time After: 0.02802 seconds
Time Before: 0.02994 seconds
Time After: 0.03140 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104543', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.04364 seconds
Time After: 0.04391 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
