Time Before: 0.00207 seconds
Time After: 0.00280 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00290 seconds
Time After: 0.00363 seconds
Time Before: 0.00388 seconds
Time After: 0.00402 seconds
Time Before: 0.00479 seconds
Time After: 0.00735 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00407 seconds
Time After: 0.01080 seconds
Time Taken: 0.00673 seconds
Time Before: 0.01267 seconds
Time After: 0.01315 seconds
Time Before: 0.01552 seconds
Time After: 0.01674 seconds
Time Before: 0.01205 seconds
Time After: 0.01693 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02197 seconds
Time After: 0.02212 seconds
Time Before: 0.02393 seconds
Time After: 0.02517 seconds
End call of global.php: 0.026800155639648
Time Before: 0.02790 seconds
Time After: 0.02809 seconds
Time Before: 0.03006 seconds
Time After: 0.03155 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=104557'
Time Before: 0.04388 seconds
Time After: 0.04421 seconds
Page generated in 0.042986154556274 seconds with 9 queries, spending 0.0085291862487793 doing MySQL queries and 0.034456968307495 doing PHP things.
