Time Before: 0.02400 seconds
Time After: 0.02964 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02972 seconds
Time After: 0.03020 seconds
Time Before: 0.03046 seconds
Time After: 0.03062 seconds
Time Before: 0.03147 seconds
Time After: 0.03399 seconds
Time Taken: 0.00252 seconds
Time Before: 0.03070 seconds
Time After: 0.03845 seconds
Time Taken: 0.00775 seconds
Time Before: 0.04786 seconds
Time After: 0.04829 seconds
Time Before: 0.05069 seconds
Time After: 0.05189 seconds
Time Before: 0.04718 seconds
Time After: 0.05216 seconds
Time Taken: 0.00497 seconds
Time Before: 0.08800 seconds
Time After: 0.08821 seconds
Time Before: 0.11244 seconds
Time After: 0.11375 seconds
Time Taken: 0.00131 seconds
Time Before: 0.12469 seconds
Time After: 0.12488 seconds
Time Before: 0.12733 seconds
Time After: 0.12901 seconds
Time Taken: 0.00168 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=10456', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14597 seconds
Time After: 0.14626 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
