Time Before: 0.00129 seconds
Time After: 0.00175 seconds
Time Before: 0.00181 seconds
Time After: 0.00229 seconds
Time Before: 0.00252 seconds
Time After: 0.00269 seconds
Time Before: 0.00362 seconds
Time After: 0.00630 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00277 seconds
Time After: 0.01166 seconds
Time Taken: 0.00889 seconds
Time Before: 0.01403 seconds
Time After: 0.01446 seconds
Time Before: 0.01612 seconds
Time After: 0.01732 seconds
Time Before: 0.01328 seconds
Time After: 0.01756 seconds
Time Taken: 0.00428 seconds
Time Before: 0.02540 seconds
Time After: 0.02554 seconds
Time Before: 0.02789 seconds
Time After: 0.02916 seconds
Time Before: 0.03259 seconds
Time After: 0.03276 seconds
Time Before: 0.03586 seconds
Time After: 0.03734 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104569' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05199 seconds
Time After: 0.05233 seconds
