Time Before: 0.04016 seconds
Time After: 0.04980 seconds
Time Taken: 0.00963 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.04992 seconds
Time After: 0.05048 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.05080 seconds
Time After: 0.05096 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.05189 seconds
Time After: 0.05458 seconds
Time Taken: 0.00269 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.05106 seconds
Time After: 0.05998 seconds
Time Taken: 0.00892 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.06773 seconds
Time After: 0.06816 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.07082 seconds
Time After: 0.07207 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.06694 seconds
Time After: 0.07226 seconds
Time Taken: 0.00532 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.14770 seconds
Time After: 0.14790 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.23744 seconds
Time After: 0.23878 seconds
Time Taken: 0.00134 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.27935 seconds
Time After: 0.27957 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.28683 seconds
Time After: 0.28832 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104577' WHERE sessionhash = 'e0f0ca8e3048a6e309b58c7aba652665'
Time Before: 0.32450 seconds
Time After: 0.32478 seconds
Memory Before: 5,998.352 KB
Memory After: 5,998.594 KB
