Time Before: 0.02482 seconds
Time After: 0.03350 seconds
Time Taken: 0.00868 seconds
Time Before: 0.03363 seconds
Time After: 0.03408 seconds
Time Before: 0.03435 seconds
Time After: 0.03448 seconds
Time Before: 0.03547 seconds
Time After: 0.03756 seconds
Time Taken: 0.00209 seconds
Time Before: 0.03455 seconds
Time After: 0.04143 seconds
Time Taken: 0.00688 seconds
Time Before: 0.05400 seconds
Time After: 0.05443 seconds
Time Before: 0.05789 seconds
Time After: 0.05909 seconds
Time Before: 0.05331 seconds
Time After: 0.05935 seconds
Time Taken: 0.00604 seconds
Time Before: 0.09592 seconds
Time After: 0.09605 seconds
Time Before: 0.11665 seconds
Time After: 0.11794 seconds
Time Before: 0.12747 seconds
Time After: 0.12764 seconds
Time Before: 0.13000 seconds
Time After: 0.13149 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=104582', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.14891 seconds
Time After: 0.14942 seconds
